Jakez 7 Posté(e) 12 février 2016 Bonjour, Vous avez peut-être lu mon post d'hier relatant un souci sur la RC de mon Alias dont le stick droit passait de 0 à100 sur moins d'un 10ème de la course. Aucun Tuto trouvé sur le net ne m'avait permis de faire un total reset. J'ai expédié hier un mail à "support@latrax.com". Dès ce matin, j'avais le réponse que je vous livre ici. Merci à Steve pour sa réactivité. Hello,First try resetting your accelerometer. https://www.latrax.com/sites/default/files/6608-Alias-Accelerometer-Reset.pdfIf that does not fix the problem you may need to set your transmitter back to the factory default settings. This procedure is different from the one in your Owners Manual.First make sure you have a freshly charged battery in your Alias and fresh batteries in the transmitterTurn on the transmitterPress and hold the throttle stick (left stick) for two seconds to access the Menu screenClick the throttle stick four times until the Reset menu shows on the screenOnce you are in the Reset menu press and hold both of the AUX buttons until CC (calibration) shows on the screen. This will take about 3 seconds.Make sure the throttle stick is in the down positionClick the right AUX button to begin the re calibration procedureLeft (Throttle) stick calibration(Please excuse the symbols. They are all intended to represent what you see on the screen and are by no means exact.)When the screen displays ^ move the left stick up as far as it will go. Leave it there and click the right AUX button.When the screen displays |_| move the left stick down as far as it will go. Leave it there and click the right AUX button.When the screen displays [ move the left stick to the left as far it will go and release it. It will return to center. Click the right AUX button.When the screen displays ] move the left stick to the right as far it will go and release it. It will return to center. Click the right AUX button.Right (Cyclical) stick calibration (This is the same procedure)When the screen displays ^ move the right stick up as far as it will go and release it. It will return to center. Click the right AUX button.When the screen displays |_| move the right stick down as far as it will go and release it. It will return to center. Click the right AUX button.When the screen displays [ move the right stick to the left as far it will go and release it. It will return to center. Click the right AUX button.When the screen displays ] move the right stick to the right as far it will go and release it. It will return to center. Click the right AUX button.When the screen displays 0 make a full circle (all the way out to the stick limits) with the left stick and release it. Click the right AUX button.When the screen displays 0 make a full circle (all the way out to the stick limits) with the right stick and release it. It will return to center. Click the right AUX button.The Transmitter will exit calibration and exit the reset menu. It will display the 00 disarm screen.Turn the transmitter off. When you turn it back on it should power up normally.If this does not fix the Traxxas handles international warranty issues through our international importers. Please contact the local hobby shop where you purchased the vehicle and see if they can help. If they cannot, ask them to contact their authorized Traxxas importer where they purchase their Traxxas products. You may need to send the part to them for evaluation. Best regardsSteveTraxxas Customer Support Please include all previous e-mails in your response to prevent delays in receiving support.If you need immediate assistance please contact our Customer Service department Monday through Friday, 8:30am to 9:00pm Central Time at one of the following numbers:US Customers 1-888-TRAXXAS (Toll Free)Outside of US 001-972-549-3000 Check out the Summit and Alias in the Redwoods Forest Recon! Partager ce message Lien à poster Partager sur d’autres sites
Jean Pierre Bayle 590 Posté(e) 12 février 2016 Super ! Envoyé de mon iPhone en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
ThorAsgard 7 Posté(e) 13 février 2016 du coup, la manipulation a résolu le soucis ? Partager ce message Lien à poster Partager sur d’autres sites
moloko 300 Posté(e) 16 février 2016 bien vu Jakez! une petite traduction serait les bienvenus pour les cancres de l'Europe en anglais Partager ce message Lien à poster Partager sur d’autres sites
Jakez 7 Posté(e) 16 février 2016 Oui, le problème est résolu. Pour la traduc, je vais m'y atteler si ça peut vous aider. Partager ce message Lien à poster Partager sur d’autres sites
Jakez 7 Posté(e) 16 février 2016 Essayez d'abord de faire un RESET de l'accéléromètre :https://www.latrax.c...meter-Reset.pdf Si ça ne solutionne pas le problème il vous sera nécessaire de ramener la télécommande aux paramètres par défaut. cette procédure est différente de celle décrite dans le manuel. Assurez vous d'abord que les batterie sont chargées dans l'Alias et dans la télécommande. Allumez la télécommande Appuyez et gardez appuyé le stick de gaz (le gauche) durant 2 secondes pour accéder à l'écran "MENU". Appuyez 4 fois sur ce même stick pour que l'écran affiche "Reset" Quand vous êtes dans ce menu Reset, appuyez et maintenez appuyé les 2 boutons AUX jusqu'à l'apparition de "CC" (calibration) à l'écran. Cela va prendre 3 sec. Assurez vous que le stick de gaz est en position basse. Appuyez sur le bouton AUX de droite pour démarrer la procédure de re-calibration. Calibration du stick gauche (gaz) (Excusez moi pour les symboles, ils tentent de représenter ce que vous voyez à l'écran, m^me s'ils ne sont pas exacts) Quand l'écran affiche "^",poussez le stick gauche vers le haut au maximum; gardez le dans cette position et appuyez sur le bouton AUX de droite. Quand l'écran affiche "/_/" poussez le stick gauche vers le bas au maximum; gardez le dans cette position et appuyez sur le bouton AUX de droite. Quand l'écran affiche "(" poussez le stick gauche vers la gauche au maximum et relâchez le; il revient au centre. Appuyez sur le bouton AUX de droite. Quand l'écran affiche ")" poussez le stick gauche vers la droite au maximum et relâchez le; il revient au centre. Appuyez sur le bouton AUX de droite. Calibration du stick droit (la méthode est identique) Quand l'écran affiche "^" poussez le stick droit vers le haut au maximum et relâchez le; il revient au centre.Appuyez sur le bouton AUX de droite. Quand l'écran affiche "/_/" poussez le stick droit vers le bas au maximum et relâchez le; il revient au centre.Appuyez sur le bouton AUX de droite. Quand l'écran affiche "(" poussez le stick droit vers la gauche au maximum et relâchez le; il revient au centre.Appuyez sur le bouton AUX de droite. Quand l'écran affiche ")" poussez le stick droit vers la droite au maximum et relâchez le; il revient au centre.Appuyez sur le bouton AUX de droite. Quand l'écran affiche "0", faites effectuer un cercle complet (jusqu'à ses limites)au stick de gauche et relâchez le. Appuyez sur le bouton AUX de droite. Quand l'écran affiche "0", faites effectuer un cercle complet (jusqu'à ses limites)au stick de droite et relâchez le. Il revient au centre. Appuyez sur le bouton AUX de droite. La télécommande va sortir de la calibration et du menu RESET L'écran va afficher le "00" du menu Désarmé. Eteignez le transmetteur; lors du ré-allumagne il doit fonctionner normalement. Si cette méthode ne fonctionne pas, contactez votre revendeur pour qu'il vous apporte son assistance ou, s'il n'y parvient pas, pour qu'il se mette en rapport avec le l'importateur de Hobby International. Il est possible que vous soyez amené à leur expédiez votre appareil pour évaluation. Voilà :-))) (Sauf erreur ou omission) 1 ThorAsgard a réagi à ceci Partager ce message Lien à poster Partager sur d’autres sites
ThorAsgard 7 Posté(e) 16 février 2016 Merci pour cette manip ! Partager ce message Lien à poster Partager sur d’autres sites
moloko 300 Posté(e) 16 février 2016 merci pur la trad Jakez par contre tu devrais éditer ton premier post et la mettre à la place de l'autre? Partager ce message Lien à poster Partager sur d’autres sites
jjgro 0 Posté(e) 27 février 2016 Et p'tet un epinglage, moderators ? Partager ce message Lien à poster Partager sur d’autres sites
the guitar hero 4 733 Posté(e) 28 février 2016 ouvre un nouveau sujet et je l’épinglerai, pas besoin de tous les commentaires Partager ce message Lien à poster Partager sur d’autres sites
