escapade
Nouvelle Acquisition
Bonjour
Voici ma nouvelle acquisition. Sorry pour l'anglais
The Lumenier DX800 is a small and compact Digital Video Recorder (DVR) for your FPV ground station. Not only can you record your FPV flights, but the DX800 includes a 32CH 5.8GHz receiver built right into it! Record your flight video with ease with the Lumenier DX800 DVR, featuring a 1 button record mode, full color 5" LCD screen and SD card recording. The bottom is threaded for a standard tripod screw making radio or tripod mounting easy.
Features
Display: 5-inch display screen (800X480).
Wireless Receiving: Built-in 5.8GHz receiver module.
Channel Switch: Supports 32 channels,With auto channel scan
Antenna: 5.8GHz SMA antenna assures excellent wireless receiving.
Recording: Supports seamless cycle and continuous video from wired/wireless cameras.
Photo: Supports function of taking pictures either from wired or wireless cameras.
AV IN:TV-IN [NTSC / PAL].
AV OUT: [NTSC / PAL].
Battery: Built-in 3200mAh high capacity Li-battery.
Speaker: Built-in speaker.
Storage: Supports up to 32GB micro SD card.
Language: Supports multiple languages.
Supports Power-saving Mode: automatic shutdown, automatic off-screen.
Automatic upgrade: Supports system automatic upgrade.
Sunshade Cover Provided: Video screen can be viewed clearly outside.
Screw-socket: 1/4-20 threaded base
Video Recording Format: MPEG-4 CODEC in an AVI file container
Specifications
Dimensions: 131mm*88mm*17mm;
Weight: 218g including battery
Modifié par DRHONEgirl69
Ajout du bonjour
