lexxirae 16 Posté(e) 21 février 2015 (modifié) Salut à tous, Une mise à jour est dispo pour nos radiocommandes Spektrum Je vous copie-colle la update note Spektrum™ AirWare™ Software DX6 version 1.02 DX7 version 1.01 DX9 version 1.07 DX10t version 1.09 DX18 version 1.08 DX18G2 version 1.03 DX18QQ version 1.05 DX18t version 1.01 New Features & Improvements Added ability of all radios to share model configuration (SPM) files with the new DX7. Added new screens to support Sound Categories. These allow you to select sounds more easily by grouping them into user-editable lists (categories) to reduce scrolling needed to find the sound you want. The radio supports up to 16 categories; this update will create default categories but you can modify or remove them as you desire. The pre-flight checklist shows the name of the model on power-up. This allows you to verify the right model is being started without having to go through the complete list first. New trainer mode “FPV” added to allow head tracker inputs to be mapped to any channel, with adjustable scaling and reversing. This mode enables easy mapping of head tracker channels to receiver ports, while not affecting flight controls. It supports both wired and wireless head trackers. Add support for Flight Pack Capacity (mAh) and Receiver Pack Capacity (mAh) sensors. Add support for ESC sensor. X-Plus channels are now able to be configured to generate warnings in 18- channel systems, in addition to the normal channels previously available. On the Model Copy utility, you are now able to select the Source model for copying. It is no longer necessary to use Model Select first. When setting up a timer in a speaking radio, a 20-second alert is now available. You can now use the “wiggle” function to select analog inputs when entering a “switch” option. Just move the appropriate switch or stick or slider and it will select it automatically. Trainer input is now more tolerant of inputs from devices such as head trackers (DX6, DX7, DX9 only). Corrections AS3X Gains telemetry screen does not show when configured to not show. Custom Voice Events of 16 steps now advance properly. Sailplane AIL>RUD mix field “Sub Switch” is now exported properly. Heli gyro trim values are aligned properly for all flight modes. Heli trim setup screen operates properly in tray radios. Digital Switch Setup does not allow selection of Flight Mode switch if the Flight Mode system is not configured. Vario volume is now exported and imported properly. Trainer inputs are not allowed to exceed Absolute Travel settings. Corrected delay between tx voltage status announcements. Telemetry screens now refer to Turbine rather than JetCat. Telemetry screens with trim displays now properly indicate centered status the same as the main screen. Sequencers and Gyros will now properly release a channel when being turned off. Note that you must completely disable the gyro for the old channel name and function to be fully restored. That is, you must set the Gain input (first screen) to INH, click NEXT, then set the mix to INH > INH, then the switch to INH. Only then will the channel be completely and properly freed up. For sequencers you only need to set the output channel to INH. “Tone” selection for inactivity alarm now operates properly (speech radios only). Audio System Changes (DX6/DX7/DX9/DX18T/DX18G2 only) Added support for more audio file types. Thousands is spoken correctly in English. When setting up custom sound events, the active switch position for steps and reset on sequenced events is utilized properly. New sounds have been added to the list. Spanish speech has consistent volume level. Ça se passe sur le site de Spektrum : http://www.spektrumrc.com/ Un nouveau fichier "Sons" est aussi dispo en français : Français_v1_07 Modifié 21 février 2015 par lexxirae Partager ce message Lien à poster Partager sur d’autres sites
xavdrone 3 934 Posté(e) 21 février 2015 Hello Merci pour l'info, c'est dingue j'avais pourtant cocher la case pour recevoir un email quand il y a une mise à jour et pourtant j'ai rien reçu Partager ce message Lien à poster Partager sur d’autres sites
lexxirae 16 Posté(e) 21 février 2015 J'ai reçu le mail ce matin même. Partager ce message Lien à poster Partager sur d’autres sites
xavdrone 3 934 Posté(e) 21 février 2015 c'est pas au point leur truc, car la mise à jour date du 19 février en plus Partager ce message Lien à poster Partager sur d’autres sites
blitz 2 247 Posté(e) 21 février 2015 Oui pas au point tu tout, beaucoup de retard...Je l'ai reçu hier, il se sont améliorer... Partager ce message Lien à poster Partager sur d’autres sites
lexxirae 16 Posté(e) 21 février 2015 Bah au final le plus important d'avoir l'info à un moment ou un autre et de faire la MAJ .... Partager ce message Lien à poster Partager sur d’autres sites
blitz 2 247 Posté(e) 21 février 2015 Perso je regarde le site régulièrement... Partager ce message Lien à poster Partager sur d’autres sites
Émile 97 Posté(e) 21 février 2015 Salut Que pensez vous de la mise à jour (pour la DX6v2)? C'est important de la faire? Partager ce message Lien à poster Partager sur d’autres sites
lexxirae 16 Posté(e) 21 février 2015 Nouvelles fonctionnalités, corrections de bugs ... oui je pense que c'est important de mettre à jour tous les matériels (radiocommandes, smartphones, ordinateurs, consoles de jeux etc ....) Partager ce message Lien à poster Partager sur d’autres sites
xavdrone 3 934 Posté(e) 21 février 2015 parfois quand tu met à jour c'est moins bien... Tu as constaté des bugs ? Partager ce message Lien à poster Partager sur d’autres sites
lexxirae 16 Posté(e) 21 février 2015 Non aucun, ma prog pour mon 200Qx est toujours opérationnelle Partager ce message Lien à poster Partager sur d’autres sites
blitz 2 247 Posté(e) 21 février 2015 Il arrive que les bugs concerne une fonction que tu n'utilise pas... Il y a aussi des évolutions, mais la pareille si tu ne tan sert pas... Sur la DX9 une MAJ a permit d'amélioré les possibilité de mixage... La MAJ vocal permet de rajouter des commendes et corriger des bug...C'est pour ca qu'il n'y a rien de 1.04 a 1.07... Mais comme Xavdrone si tu na pas de problème ou besoin des fonction ajouter c'est pas une obligation... Le vocal c'est pareille, c'est surtout la télémétrie qui a évoluer...Perso je suis rester longtemps sur la 1.03, la 1.07 amène surtout le classement des son... Partager ce message Lien à poster Partager sur d’autres sites
xavdrone 3 934 Posté(e) 21 février 2015 moi j'ai pas de son mais PsycoPatt il à du son sur sa radio et vous allez l'entendre très très bientôt, mais j'en dit pas plus (suspense) Partager ce message Lien à poster Partager sur d’autres sites
Émile 97 Posté(e) 21 février 2015 (modifié) moi j'ai pas de son mais PsycoPatt il à du son sur sa radio et vous allez l'entendre très très bientôt, mais j'en dit pas plus (suspense) Je déteste les suspens. Je suis trop impatient. Il a acheté une des dernières Spektrum ? Modifié 22 février 2015 par PsycoPatt Partager ce message Lien à poster Partager sur d’autres sites
xavdrone 3 934 Posté(e) 21 février 2015 il m'a envoyé un bel article et on entends sa radio parler (et lui aussi avec son super accent qui nous fait penser à la ravissante Julie ) Partager ce message Lien à poster Partager sur d’autres sites
PsycoPatt 404 Posté(e) 22 février 2015 Il a acheté une des dernières Spektrum ? j'ai la DX9 Black Edition depuis ca sorti au mois de decembre. Je l'adore Partager ce message Lien à poster Partager sur d’autres sites
PsycoPatt 404 Posté(e) 22 février 2015 et lui aussi avec son super accent qui nous fait penser à la ravissante Julie alors vous allez bien rigoler...mdr désolé, j'a pas beaucoup d'instruisance, j'ai rien comprendu à l'école. Partager ce message Lien à poster Partager sur d’autres sites
xavdrone 3 934 Posté(e) 22 février 2015 par contre c'est la merde ta radio parle mais n'a pas l'accent Canadien ça gâche un peu la vidéo. Partager ce message Lien à poster Partager sur d’autres sites
blitz 2 247 Posté(e) 22 février 2015 par contre c'est la merde ta radio parle mais n'a pas l'accent Canadien Partager ce message Lien à poster Partager sur d’autres sites
blitz 2 247 Posté(e) 23 février 2015 c'est pas au point leur truc, car la mise à jour date du 19 février en plus La MAJ date d'avant, le 9 février elle était déjà dispos.... Partager ce message Lien à poster Partager sur d’autres sites
Atmos 9 Posté(e) 30 avril 2016 Bonjour à tous, Hier j'ai fait 5 vols avec deux modèles différends sans aucun problème, puis au changement de batterie, tous mes modèles se mettent en mode affection mais la radio commande ne fait rien 'Affection pendant 3-4 minutes puis Echoué. Je viens d'installer la version 1.10 mais toujours pareil. Quelqu'un connait t'il les combinaisons de manches pour revenir à la version d'usine (Reset) Merci et bon vol. PS. Heureusement il pleut mais je ne peux pas configurer mes nouveaux jouets. Partager ce message Lien à poster Partager sur d’autres sites
the guitar hero 4 733 Posté(e) 30 avril 2016 tous mes modèles se mettent en mode affection mais la radio commande ne fait rien 'Affection pendant 3-4 minutes puis Echoué. ne cherche pas, ta radio est amoureuse, va l’inscrire sur meetic 3 xavdrone, DRHONEgirl69 et Djkill972 ont réagi à ceci Partager ce message Lien à poster Partager sur d’autres sites
Atmos 9 Posté(e) 30 avril 2016 Ok, j'essaye Partager ce message Lien à poster Partager sur d’autres sites
Djkill972 64 Posté(e) 30 avril 2016 Mdr...[emoji131] Partager ce message Lien à poster Partager sur d’autres sites
